I have mine mounted off one of the pinion snubber holes, if you have that style of Dana. If not what about a bracket bolted to the webbing on the side?
I will assume he doesnt have the snubber holes...
all I can suggest John is to drill and tap the housing...
I've seen a couple of dana's done that way... they
had 2 1/4 X20 bolts holding it on
