So...the general consensus is the Mopar Box is too flimsy a deal? And I saw it was mentioned but I don't recall an answer - is the front spring eye on a Chevy 25" mono leaf the same width as a Mopar leaf? If not, what is the width, and if a different width front bracket needed - heck a different / longer Cal Trac bar needed? If you had the Mopar bar already can it still be used, maybe with a few more parts and pieces, or does it too have to be changed?
I have a Mopar A body Cal Trac bar / Mono leaf set but have yet to install it, nor install any sort of relocation spring box, but this topic has me thinking ahead to maybe considering setting it up ahead of time to accommodate both the Chevy 25" front segment leaf and Mopar leaf, with additional holes, if possible. Better to do it once, one time...
The Mopar or similar boxes are fine as many use them and once in place washers can be welded on the outside of the hanger for extra strength. The ft. 25" segment has the same eyelet and sizing as the Mopar one so it just bolts in but moving it 5" foreward is interesting and if you have a plasma cutter, you could cut the time WAY down............pics soon of the butchery then final photos to follow.
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
