nice 3in wide 25in long front all GM that is the best way to go. I don't know if you will have room for three holes in the torque box because the large bolt in the caltrac bar will hit the box in the upper hole I would thank you would need at lease 1in in between the holes but not sure
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
