Thanks for the replies. So then, I should be able to check for continuity between the case and the engine block and if it's there, I'm good?
No.. You want to use a heavy guage wire from that stud to the engine. All the factory cars and trucks had a ground wire. You alternator is mounted with rubber isolators thats why there was a HD wire on the car. I would ask for another correct alternator.
"That stud" represents nothing more that an electrical connection to the case. As long as the the alternator is NOT isolated (electrically) he's fine. I did not read they the posts carefully, but I thought he is using this alt in a non stock application. I could be wrong.
