You can, but there are good reasons not to, including the limited availablility of those drums. I have routinely found 10x2.5 brake systems in the self-serve yards with fresh brakes. Might be up to about $75 now, but the last set I bought was $50...
The only potential issue with going to this setup is that it widens the rear track 1/4" each side , shouldn't be an issue on a the Demon/duster body.
