I'll put that together as a set and probably add it to my Challenger gasket set.
I'll get you a set for compiling the info.
What is the OD/ID again of the thin white ones? I'm gonna assume like .187" or .250" thick. Like you said probably more of an anti rattle then a seal.
Thank you Jim.
Thin white washers=
ID = ~0.160"
OD = ~0.460"
0.105-0.110"
