I'll put that together as a set and probably add it to my Challenger gasket set.
I'll get you a set for compiling the info.
What is the OD/ID again of the thin white ones? I'm gonna assume like .187" or .250" thick. Like you said probably more of an anti rattle then a seal.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
