Ok.
if the foaming issue and not being friendly with ABS systems is true, then I can't run it in my Dakota...I've got 13" rotors with 4-piston viper calipers on my rear axle, needless to say, I NEED the RWAL to keep me from locking up the rear too soon. (because of the factory RWAL is the only reason I was willing to put such big brakes on the rear)
you can always run one of those adjustable valve to get the bias correct...the main reason not to run dot 5 ive found is its 25$ a quart
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
