The rollers on the Johnson are probably smaller - allowing the larger skirt. Ideally you want the biggest roller possible. The skirt isn't an issue unless it uncovers the oil galley at full lift. As for the AMC lifters, apparently the oil hole is wrongly situated for Mopar use and will bleed off too much pressure because its fully exposed to the oil galley.
.The "Skirt" or the cutout around the wheel is the problem on AMC's losing oil Pressure..at full lift like you say...
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal
5.97 115.73 Coles county dragway 10/28/07
9.42 142.96 best in 08(6.00 115.8 1/8)
5.97 116.2 in 09
http://www.youtube.com/watch?v=AXSr201-tmA
