The rollers on the Johnson are probably smaller - allowing the larger skirt. Ideally you want the biggest roller possible. The skirt isn't an issue unless it uncovers the oil galley at full lift. As for the AMC lifters, apparently the oil hole is wrongly situated for Mopar use and will bleed off too much pressure because its fully exposed to the oil galley.
