not sure if this helps
This ALL helps a lot! Thank you.
My first guess is it's probably a vacuum leak. The fuel tank has never been down and otherwise there should be no damage to the wiring but you never know until one gets out there and probes around with a multimeter.
I have a pretty good professional background in automotive electrical troubleshooting, but no access to the particular tech info, so all that info is a great start.
Thanks again! ![](/ubbthreads/images/graemlins/beer.gif) Dean
R.I.P.- Gary "Coop" Davis 02/09/68-05/13/04
