Make sure the cap is sealing well as mentioned before. Probably just a split EVAP hose. This is very common. Check for this at the throttle body, EVAP check port, purge solenoid, and charcoal canister for a bad hose.
this , I had the same thing on my Grand cherokee , hose ...
