motor was rebuilt 2 years ago, heads were milled slightly, used the thinner fel pros to keep compression up. changed oil and no sign of coolant in oil, must be very small leak cause like I said just the small drops of green by the bolts. car runs awesome. thanks for advice and will do the test, although am thinking about just sealing the bolt and try it, could it hurt?
Yes just put sealant on all the bolts , that will tell you if the head bolt hole is damaged ... because it is not supposed to be in the coolant ... if it still leaks then it's either the head gasket or the head is cracked ...
Good luck
