Found an old photo of the tag.
As you can see it was originally a B5 Blue 440 R/T (4bbl) with white vinyl top, white interior, and white Bee stripe.
When I bought it in 1989 it had front end damage. The passenger side front fender, front grille, and possibly the passenger door (the door mirror for sure) are not original to the car.
The engine and trans are the original numbers matching items. Although the only original parts to the engine are the block and con rods.
It came with AC, PS, power drum brakes. All of which are no longer on the car.
