Come back with ALL the markings on the engine ID pad under the distributor and we'll be able to tell youmore than you dreamed possible about how it was originally built.
One of the neat things about Mopars is engines in a family used the same block and head castings no matter if they were HP or 2-barrel. So all you have told us so far is that it's a 440, by the block casting number.
R.
