I am gonna buy a stroker kit from a guy for a 500" low deck with Eagle crank, Eagle H-beam rods, and JE flat top pistons.
Main bearings are MS876P which Summit has in stock so I'm good there, $94.95.
Rods call for CB527HD bearings, Summit doesn't have them but they suggest CB527HND which they do have in stock. Are these the same? About $144 for the set.
And last, it calls for JE rings J100008-4375-5 which Summit doesn't sell and they seem expensive through JE at $182.......
http://www.jepistons.com/Products/J10008-4375-5.aspxAny better priced options here? Does Summit offer Rings similar to these?
Starting to wish I'd just stuck with a 440 or a low deck 451.
