Post 'em if you gottem! Interested to see how A bodies sit with Cal Tracs mono's or stock leafs and small tires (small meaning like a 275/60 DR, or a 28 X 10-ish). I see Calvert sells their split mono's w/ a 1" drop. I don't like the SS spring look with the rear raised, so looking at the Calvert setup. For budgetary and baseline reasons, probably stick with the factory leafs for now.
