that entire wire can just be removed from the harness since it isn't connected to anything at either end.
Or...I can remove the external voltage regulator then connect the two wires (Fld & Ign) that were connected to it and just connect the end that was to the old alternator to the "switched" spade on the new Denso?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
