Isn't the other end of that field wire just hanging out in space now that you've removed the stock alternator? Unless I'm missing something, that entire wire can just be removed from the harness since it isn't connected to anything at either end.
OK, right. What's done with the field wire that is connected to the external voltage regulator?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
