Help me to understand here. These 4 piece sets go on the inboard seat studs, one plate on top and one on bottom?
If you don't use them when you switch to buckets what happens? Does the floor tear? Really? Am I missing something?
Plates go on top of floor only, inboard holes only, and are tack welded in.
Yes the floor will eventually fatigue crack and the bolts/nuts will pull through the floor.
I made mine from some scrap plate.
Thanks. The pics make it clear. Wish I would of thought of this before I put the Dynomax and carpet in.....
Maybe some big washers on the bottom side...?
I'd pull the carpet, cut the mat and add them on the top Kevin. A washer on the underside is better than nothing, but not by much.
I have a few extras cut if you want them. Oversized but they fit a stock A body.(the plate pic was of a 72 Demon) You'll have to drill the holes yourself
