Black n Blue Charger runs the glen very well and the alleged small brakes are not an issue...yet. The actual owner/driver is a very very good driver and pushes the beast nicely. Since ole black n blue was braking and running faster than an SRT8 Challenger I would say the brake package is good.......
I have learned that no matter what braking set up you have all need ducted air to run hot laps. Bigger is not better without air. Sure bigger brakes will shave a few seconds off the lap times but at what cost and what tires and rims will be needed for the extra manliness. It's all about a balanced package.
Large rotors, wilwood calipers, the proper pads, rear wheel ford style disks from Dr Diff. Air on all 4.
