Quote: Well said! The question was posed because I went big block and needed to purchase a radiator. The recommendations poured in and left me . I felt a 22" should handle it fine but I didn't want to purchase one then find it was not quite enough. So I'm leaning toward a Champion 26" 3 row without cutting my rad support area as apposed to a 22".
If you go 26" cut it and use a shroud, it's no good blocked off.
