My 51 Ford had an overdrive. Once you got over 30-40 MPH you let up on the gas and it goes into overdrive. There was a lever that you pulled to lock out the overdrive. Worked great except the trans was so weak my flathead would break second gear frequently. It had nothing to do with my driving Ha HA
