you might look at an ebay seller called scarebird---he has a bunch of lazer cut adapter plates that disc up older cars---also one of my friends did his rear discs on a 35 plymouth with a lincoln rear rotor covered with a subaru front caliper--the subaru front has an E-brake cable that is so flexible you can tie it in knots...bob
