OK thanks!The .004 sounds like a lot of taper though,I would think .001/2 would be enough to be sure it seals all the way around well. I will have to wait to do a more accurate measurement when the heads get torqued down. I have some .080 aluminum I am making a spacer from and port matching to use if needed later for mockup or otherwise.Thank you.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
