I have a thousand into the wiring, I used the stock fuel pump, made my own stainless tank, all the fittings and what not, I'll have 5 grand into it easy. But I also rewired the whole car, new aluminum radiator, put the ac delete pulley on it, made my own driveshaft, All new auto meter guages and all the little stuff.
But it starts with a simple turn of the key and it idles perfectly. Cant beat the oem engineeering. All the hotwire wires clip right together, it took me ten minutes to wire that part.
Todays gas and carbs dont mix. Fuel injection is the only option it seems.
