Here's something positive for you to consider. That build would be perfect for a small procharger. Just make sure you check valve to piston clearance and install that cam @ 112. 6 to 8 lbs of boost will wake it up with what you already have. Forget the No2, it'll melt your pistons if you don't "tune" it just right, just a thought, Steve
Engine by DeTar http://www.kansasbadman.com
