Part 2 - I pulled up my pants and went ahead and opened the canister. No pressure. Very little fuel. Had a new filter on the shelf, stuck it in, ran though about a dozen or more prime cycles, no joy. Opened it back up, still not fuel. Tried priming again, still no joy.
Lift pump?
I can hear a pump buzzing near the filter when it should be priming, it goes for a while then starts to sound like it's dead-heading before it clicks off. Is that the lift pump or the injector pump that I'm hearing?
Any other ideas?
Thanks again
