Quote: Camper 9000 trucks also ran a pocketed lower control arm with bigger ball joint.
So did all True 1ton trucks with the 4400lb front axles. I say True 1ton because when a D350 has a 3300lb front axle rating its a halfton pretending to be a big boy
