I just made a template from the stock LCA using the ball joint as a location point and then transferred it to the Van LCA....worked like a charm
Picture of the Van LCA with located holes
Hope this helps
Also....we never had to limit the suspension travel....even with the stock /6 coils....but I did trim the bump stops down quite a bit....has never bottomed out
