I wish that I could tell you which spacer, type of material and hieght and which type, four hole or open, spacer to use but I can't
![](/ubbthreads/images/graemlins/bawling.gif)
YET
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I have several tunnel rams that I want to try soon, including a Indy tunnel ram with M.W. ports for a low deck and a pair of Rons terminator throttle bodies with his injection kit using E85
![](/ubbthreads/images/graemlins/thumbs.gif)
The bad thing about tunnel rams and different hieght and type spacers is the throtte linkage length from the bottom bellcrank to the upper arm, I have three different length arms now so I hope they will cover the different spacers I want to try on that Indy intake
![](/ubbthreads/images/graemlins/luck.gif)
I have several different spacers to try, one inch phenolic spacers like in this picture under the Holley carbs. on the Mopar tunnel ram
![](/ubbthreads/images/graemlins/scope.gif)
I also want to try two sets of two inch high aluminum spacers, both open and four hole, a pair of 1.5 inch tall Wilson aluminum 4500 reversion spacers and finally I want to try a set of two inch tall tapered Dominator to 4150 adapters to use the Terminator throttle bodys on the 4500 intake top so I can mount the terminators in line instead of sideways like the way the Indy manifold tops are stock
![](/ubbthreads/images/graemlins/image_294343.gif)
