i have read that some of the guys here have ordered 1/2 stainless fuel line from fine lines that was pre bent...how did it fit?????
i am also considering ordering the return line in 3/8...i konw our cars came with 3/8 fuel with 1/4 return and i am wondering if 1/2 fuel and 3/8 return will fit with minor tweaking in factory location ???
i really want this set up to work for my 700hp efi project...any thoughts will help.i posted this under question and answer and got no response so any info will help...
I wanted to run stainless with the factory style quick connects on my efi system, and not use any AN adapters, but I could not flare the stainless with the hyrdaulic tool.
I went with aluminum, used scotch bright and put a brush finish on it. Now no rust on the inside or out, its easier to manipulate that steel or stainless, and was cheaper.
My opinion.
I also used the rock valley set up. Very happy with their set up.
JM
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
