What type of dist./oil pump drive gear are you using? I've seen the gear slip on the shaft of the non-heavy duty gear drives. The heavy duty ones have the pin thru the gear and shaft. Just food for thought.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
