I`d go moly top, napier second and standard tension oil unless you run a vac pump. I run this set up w/out a v-pump and med tension rings and have just a bit of blow-by so I may end up installing a pump just to help w/leaks and ad maybe controll blow-by a bit...........
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
