Cool - great advice so far, thanks.
So for rocker arms, which are considered to be the best for longevity?
Aluminum arms such as Crane Gold, Harland-Sharp etc. or go to a steel arm such as Comp Cams?
Is there anything special that has to be done to control thrust on the camshaft (special thrust buttons etc) or just bolt it in?
The best rocker arms are something like jesel pro steel rocker arms but as far as I know they do not sell them for BB mopars.
T&D or jesel makes a good Aluminum rocker.
Yes you will need a cam button and it is a good idea renforce the timing chain cover.
