What size eng and is it the stock intake ? Could be the crossover clogged but depending on the year and temp it can also have a problem with the electric assist choke. Over about 60 degrees the electric assist choke would open the choke fully in about 1 minute. Under that it needed the heat from the crossover and some electric help down to a certain temp. I cleaned many intake exh crossovers over the years. Ron
