What size carb are you guys running on your small block strokers. This car is 99.9% street driven with a trip to the track every 2 to 3 years. Here is my combo. Thanks in advance for all advice.
418 CI
10.9 to 1 Comp.
Ported Edelbrock Heads
Solid Flat Tappet (Dur. 254 Int. 262 [Email]Ex.@.050[/Email] Lift 540 Int. 555 Ex.)
Ported Super Victor Intake
TTI Step Headers 1 5/8 - 1/78
3.91 Gear
4 Spd.
Wieghs 3200 lbs.
I built a 418 for my Rampage and went with a 850DP
and it made 550hp and 520ftlbs ... this was with W-5
heads and 1 7/8 tubes, same compression.. it would
have made more power with a bigger carb but this was
enough power to put me at my max ET in my car...
strokers really like CFM but it comes down to how
much fuel you want to throw at it on the street
