I have one of the negative straps from the neg battery cable itself and the fender ground strap on the motor. I don't think grounding is the issue. I will investigate replacing the sender with the Moapr unit.
Anybody have a part number or source of where I can get the "official" sender for my car? Should be the same as the 60s thru the 70s and probably 80s as well....
