explain about the petronix kit, does it eliminate the ballast and ecu box or?? Is it as good as the stock electronic ignition? Does it have as hot a spark as electronic? Reliable?
(1) Yes (2) better (3) hotter!) (4) Scratchn reports it is flawless for years
