Thanks again!!
Will do.
That was exactly the reason I asked. I knew with shaft oiling it had to be oiling the shaft and rocker arm from the inside as well.
Converting over to Push-rod oiling with a set of standard LA shaft rockers wouldn't get oil inside the rockers and shaft.
I'll look around and see what I can find. Pretty sure Jesel probably does to but the price would be about the same.
