Thinking of Putting LA style heads on a Magnum Block. (Airwolf 220s)
I know the Magnum Block can be drilled for Shaft oiling.
BUT would push-rod oiling be better or just as good?
Who makes new shaft rocker set-up for LA heads? Preferably in 1.7:1 ratio.
Do the rockers need anything special for PushRod oiling???
I use TD rockers...the one thing you need to make
sure of is that a oil through PR rocker has the oil
hole in the cup to push oil to the rest of it... some
rockers that shaft oil have a hole that points towards
the cup so that wouldnt work with PR oiling
Thanks Mr P Body!!
I was hoping to find something a little cheaper than the T&Ds. Got those for my W9RP heads and know they can also be had with through arm oiling to the valve stem.
Trying to get a BEST BANG for the BUCK on this engine and not go overboard. Already did that with another engine I have.
If that's the Only real option I may reconsider another head Option I was contemplating because that drives the price close to what I was quoted for the other heads.
