Broke one in my 12 second Duster when it was a stick car. Since then I've gone 9.70's with a solid small joint in the front yoke with an automatic, trans brake at 2700 pounds.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
