Driver's side post is tacked in place. Fitment on this side is proving a bit tougher. Apparently there's production variation in door opening height from side to side, as the driver's door is a slightly tighter fit up and down than was seen on the passenger side. We wondered if perhaps someone had redone the bottom of the door at some point and it ended up being taller. Will find out once that one is stripped down.
