My crate motor has the thin balancer. I order alum pulleys from mancini. The crank pulley needed a .37" spacer to achieve alignment. I painted the pulleys black, and I think I had to elongate one hole. I think the pulleys were around $150.
THis was about 4 years ago, but everything is still fine.
hope this helps.
