Jeff makes some good points, .. first and most important is the hourly labor rate. $75 to $100 an hour for our expertise is the proper rate. The VALUE of the work you do is much greater then $45 and hour.
Curtis
curtis , you're killing us here , my junk isn't worth $75-100 an hour ...
