" silver fence paint"....means you need to pull it back out and apart.
I'd suggest enlisting some experienced help from your machinist or a builder on the re-build.
good luck...
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
