What ignition system do you have? That will help figure out the correct coil/ ballast to use.
I ran that same Accel coil for many years with an MP chrome box. I still have it and ran it on the dyno with a couple different boxes. It worked slightly better than the MSD Blaster 2 up to around 5000 rpm on a street engine. Maybe they outsource them now and the quality is no longer there?
You could run a Blaster 2 or 3 and never notice the difference,on a 310 hp engine it was barely noticeable.
Keith
