I've been working on a nagging issue I've had with my 71 Cuda for quite a while. When the brakes are applied hard/quickly I get a pull to the left. I've replaced all springs and had the wheel cyclinder apart. I didn't replace because the cylinder appears to work just fine. The master cyclnder is fairly new but I don't see that being an issue anyhow. I'm beginning to wonder about the proportioning valve. In all my years I've never had an issue with that or ever replaced one. Any ideas/suggestions? Thanks!
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
