Rather than try to weld the 360LA weights on the later flexplate in the same position they would be on the converter, you could place the weight out near the outer rim like the 360 Magnum. It would take some math; knowing the 360LA imbalance is 19.79 inch-ounces...extrapolate that into the inches the rim is from center.
The INTERNET, the MISinformation superhighway
