I run Rancho adjustables on the back,stock gas on the front. Original main leafs,still with the oval rubber bushng. The spring pack is from a 69 GTX with the pack turned around backward to soften the rear segment and stiffen the front. I raised the front eye by flipping it upside down. 3875lbs mid 1.50 @60ft.
